Is one to one NAT possible with Asuswrt?
waspinator
I'm trying to set up my multiple public IPs to point to multiple private IPs. This is useful for me since I have a few 'servers' that all use the same ports. I know I could use port forwarding with port translation, but I don't want people to have to enter custom ports.
Is there a way to configure Asuswrt in a similar way to this guide?
http://www.dd-wrt.com/wiki/index.php/One-to-one_NAT
I tried copying the script into
/jffs/scripts/nat-start
and running
chmod a+rx /jffs/scripts/*
but I can't access the computers using the external IP...
#!/bin/sh
#/jffs/scripts/nat-start
# router WAN configuration
# Static IP
# X.X.X.X.30
## WAN X.X.X.X.31 -> LAN 10.34.1.4
ifconfig eth0:0 X.X.X.X.31 netmask 255.255.255.0 up
iptables -t nat -A PREROUTING -i eth0 -d X.X.X.X.31 -j DNAT --to-destination 10.34.1.4
iptables -t nat -I POSTROUTING -s 10.34.1.4 -j SNAT --to X.X.X.X.31
# open ports 80 and 443
iptables -A FORWARD -i eth0 -p tcp --dport 80 -d 10.34.1.4 -j ACCEPT
iptables -A FORWARD -i eth0 -p tcp --dport 443 -d 10.34.1.4 -j ACCEPT
## WAN X.X.X.X.32 -> LAN 10.34.1.5
ifconfig eth0:1 X.X.X.X.32 netmask 255.255.255.0 up
iptables -t nat -A PREROUTING -i eth0 -d X.X.X.X.32 -j DNAT --to-destination 10.34.1.5
iptables -t nat -I POSTROUTING -s 10.34.1.5 -j SNAT --to X.X.X.X.32
iptables -A FORWARD -i eth0 -p tcp --dport 80 -d 10.34.1.5 -j ACCEPT
iptables -A FORWARD -i eth0 -p tcp --dport 443 -d 10.34.1.5 -j ACCEPT
## WAN X.X.X.X.33 -> LAN 10.34.1.6
ifconfig eth0:2 X.X.X.X.33 netmask 255.255.255.0 up
iptables -t nat -A PREROUTING -i eth0 -d X.X.X.X.33 -j DNAT --to-destination 10.34.1.6
iptables -t nat -I POSTROUTING -s 10.34.1.6 -j SNAT --to X.X.X.X.33
iptables -A FORWARD -i eth0 -p tcp --dport 80 -d 10.34.1.6 -j ACCEPT
iptables -A FORWARD -i eth0 -p tcp --dport 443 -d 10.34.1.6 -j ACCEPT
I tested to see if the ports were open using yougetsignal and they are all closed.
How would I use the webUI to forward ports from each WAN IP to each LAN IP?
edit
typing `ifconfig` into the terminal does not show any extra eth0 configured interfaces. this is the only eth0 entry
eth0       Link encap:Ethernet  HWaddr AC:XX:XX:XX:XX:XX
           inet addr:X.X.X.30  Bcast:X.X.X.255  Mask:255.255.255.0
           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
           RX packets:58487 errors:0 dropped:0 overruns:0 frame:0
           TX packets:52620 errors:0 dropped:0 overruns:0 carrier:0
           collisions:0 txqueuelen:1000
           RX bytes:8369465 (7.9 MiB)  TX bytes:19643974 (18.7 MiB)
           Interrupt:4 Base address:0x2000
dmesg | grep eth0 doesn't mention anything interesting either
# dmesg | grep eth0
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.110.27.20012
device eth0 entered promiscuous mode
is there a way to check if the router is doing anything, where it's failing, or where I have errors in the script? should I be putting things in another place? https://github.com/RMerl/asuswrt-merlin/wiki/User-scripts
edit2
If I copy and paste each command into the terminal then the port forwarding works as expected. is the nat-start file supposed to have a file extension? if so what should it be? Is there a place I can just copy and paste the script into the webUI?
edit3
and it works. I must have had the wrong encoding in the file. I copied the text, deleted the file, and created a new one using vi and pasting it back in.
out of curiosity are there any firmware versions available for our routers that have a webUI to help out with this kind of set up?
