Is The /etc Directory Persistent?
HarryMuscle
Could someone clarify whether the /etc directory (and the files in there) are persistent between reboots? For example, if I create a second stubby.yml configuration file and store it in the /etc/stubby directory, will it persist after a reboot? I'm fully aware of the /jffs/configs directory that should be used for custom configuration files, but I'm specifically curious to know if the /etc directory is persistent between reboots.
Thanks,
Harry
Thanks,
Harry
Try it.
touch test.file
reboot
see if still there
/etc is a symlink to /tmp/etc FYI
Thanks,
Harry
Put the file on jffs and use a script to create a symlink on every restart.
