thewizard1241
if you only have a 200mb down and 100mb up connection?
Or is it more usefull in the 1GB range?
Makes sense, Thank you!The more clients you have connected and being used concurrently, the more 'point' of having the more powerful consumer router 'now'. Regardless of the ISP speeds.
I think 6E will be the best thing since sliced bread. That said It to will eventually saturate as well. But it may take a few years.![]()
but don't you need wifi 6 or mu-mimo devices to take advantage? I got tha ax58u thinking it would handle more devices better then my ac66u_b1 but I was very disappointed. Still flakes out if you start hiding networks or adding mac addresses for more then 20 devices. Seemed even less stable dropping wifi connections. I returned it and went back to the ac66u. Even though I do have a couple wifi 6 devices. The only thing that seemed to be an improvement was the wifi range especially the 5ghz. Speeds weren't any different since like the above user I only have a 100MB line.The more clients you have connected and being used concurrently, the more 'point' of having the more powerful consumer router 'now'. Regardless of the ISP speeds.
Yes, you need matching devices to take advantage of features in newer standards. Older devices can get some benefit from better radio RF and perhaps better airtime fairness implementation.but don't you need wifi 6 or mu-mimo devices to take advantage?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
