Switching Routers; do what first?
not really necessary in my case
Getting tired of this... Your use case is YOUR use case. The OP may have different use case. Thanks for sharing though. 🫤
Swapped ok (with a couple of glitches).
Considerably more power consumption (2 to 2 1/2 X) and the resulting heat with the Netgear over the TP Link which is why I mount these vertically with 'spacer feet' to increase air flow from the bottom of the enclosure.
U Want to move away from Asus routers, Ubiquiti? advice needed Routers 134
âś–
