Isolated AP - allow IP address
Bagetak
Hi, I want to have my router in AP isolated mode but then my devices can't communicate with my DNS server. I have an external dns server on my network. I don't want to use the router itself as upstream dns server. Can I allow ip addresses to be accsesible trought some script?
Isolated AP should only prevent wireless clients from talking to each other. Assuming your DNS server is wired you probably just need to check the firewall rules (ebtables and iptables) and see if Asus is adding something to block access to wired too. Are you using guest network with intranet access disabled?
When I am connect to WiFi AP isolated Wifi I can't communicate with anything. DNS server is wired. I am using main wifi settings Wireless->Professional->Set AP Isolated
