I have an issue with my work laptop unable to connect to the router wifi (it was happening with latest stock firmware, I tried installing latest Merlin, but nothing changed).
The issue is kinda weird. If the laptop was last connected to my home wifi when hibernated, it does connect back with no issues when rebooted.
However, when I come back home from the office, theres no way to make it connect to my home wifi until I either reboot the router, or disable/re-enable the wifi antenna of the router.
This has been happening since a few months ago, I ve had this router from a couple years.
I havent noticed any other home wifi devices having similar issues connecting.
Checking the router logs while the wifi connection of the laptop was failing I had several entries, but none of them seem to be related to the laptop (as the mac addresses are from other devices).
Also, the laptop has a static dhcp address set in the router.
A few log examples, but again, the mac addresses are from other devices in the network :
Checking the logs from the whole day, the mac address of the laptop only shows up after successful connections or expected disconnections (due to inactivity after powered off).
If this was solely an issue from the laptop, Id not expect it to go away when just rebooting the router/re-enable the wifi antenna... am I missing something ?
Thanks.
Oct 7 14:16:15 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 7C5:66:5F:90:BC, status: 0, reason: Unspecified reason (1), rssi:0
Oct 7 14:16:15 wlceventd: wlceventd_proc_event(685): eth6: Auth 7C5:66:5F:90:BC, status: Successful (0), rssi:0
Oct 7 14:16:15 wlceventd: wlceventd_proc_event(722): eth6: Assoc 7C5:66:5F:90:BC, status: Successful (0), rssi:-51
Oct 7 14:16:15 hostapd: eth6: STA 7c:d5:66:5f:90:bc IEEE 802.11: associated
Oct 7 14:16:15 hostapd: eth6: STA 7c:d5:66:5f:90:bc RADIUS: starting accounting session B02F13DF64DC7327
Oct 7 14:16:15 hostapd: eth6: STA 7c:d5:66:5f:90:bc WPA: pairwise key handshake completed (RSN)
Oct 7 14:16:15 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 20:A1:71:06:C3:8A, status: 0, reason: Unspecified reason (1), rssi:0
Oct 7 14:16:15 wlceventd: wlceventd_proc_event(685): eth6: Auth 20:A1:71:06:C3:8A, status: Successful (0), rssi:0
Oct 7 14:16:15 wlceventd: wlceventd_proc_event(722): eth6: Assoc 20:A1:71:06:C3:8A, status: Successful (0), rssi:-67
Oct 7 14:16:15 hostapd: eth6: STA 20:a1:71:06:c3:8a IEEE 802.11: associated
Oct 7 14:16:19 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 34:38:B7:25:A9:86, status: 0, reason: Unspecified reason (1), rssi:-52
Oct 7 14:16:19 wlceventd: wlceventd_proc_event(685): eth6: Auth 34:38:B7:25:A9:86, status: Successful (0), rssi:-52
Oct 7 14:16:19 wlceventd: wlceventd_proc_event(722): eth6: Assoc 34:38:B7:25:A9:86, status: Successful (0), rssi:-52
Oct 7 14:16:19 hostapd: eth6: STA 34:38:b7:25:a9:86 IEEE 802.11: associated
Oct 7 14:16:19 hostapd: eth6: STA 34:38:b7:25:a9:86 RADIUS: starting accounting session 0A5CDCFB53B333FE
Oct 7 14:16:19 hostapd: eth6: STA 34:38:b7:25:a9:86 WPA: pairwise key handshake completed (RSN)
Oct 7 14:16:20 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 20:A1:71:06:C3:8A, status: 0, reason: 4-way handshake timeout (f), rssi:-67
Oct 7 14:16:20 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 20:A1:71:06:C3:8A, status: 0, reason: Disassociated due to inactivity (4), rssi:-67
Oct 7 14:16:20 hostapd: eth6: STA 20:a1:71:06:c3:8a IEEE 802.11: disassociated
Thanks.
