Just bought Asus RT-AC66U
PainKiller89
I was wondering which firmware would be the best for the router. I am basically looking for gaming wise and downloading wise.
The latest version available is the best for that model, unless you have a very high speed PPPoE connection and need HW acceleration, in which case the 354.29 Beta 1 is the last known version with working HW acceleration for PPPoE users.
Thank you very much for your response. I am currently using cable with 30 down and 5 up. But with the docsis 3.0 modem i am pulling about 55 down. So do you recommend using 354.29 beta 1? or use the latest?
You're one cable, so the PPPoE-specific issues do not apply anyway. Go with 374.35_2 or 374.36 Beta 1.
