randomName
I recently logged into my router via putty to update Skynet & FreshJR, and after a reboot I'm getting 3 of those messages a second in my router log. What's going on with this? I thought I exited putty properly.
Skynet probably didn’t start properly. Those are the normal firewall drop logs that SkyNet enables then replaces with its own format.
If your USB drive is mounted properly, try reinstall with “firewall install” command.
Welcome To SNBForums
