KillSwitch doesn't work anymore on RT-AC86U (386.3_2)
Onilaq
Hi, after the upgrade to firmware 386.3_2 the killswitch feature doesn't work anymore.
When I stop the vpn client the routed clients "switch" to wan and continue to stay connect. Before the upgrade they would've just stop but now that function doesn't work anynmore.
I tried to add 192.168.1.0/24 (all clients) and also with manual ip addresses .... but nothing changed.
Could you help me to resolve this problem?
octopus
Part of the Furniture
I've already read that thread but before the upgrade when I switched manually off the vpn all the connection to it stopped. Now it doesn't do that.
Maybe I should downgrade to the previous version.
Its working just fine. But you testing it in a wrong way. Use "killall" and test again. There is som instruktions in wiki to read.
Onilaq
Is there a way to use killswitch like in the old fw version? If I voluntery/manually stop the vpn client its blocks the connection.
eibgrad
Onilaq
Thanks for that, I didn't think about iptables.
Btw with REJECT I got this error:
Bad argument `REJECT'
Try `iptables -h' or 'iptables --help' for more information.
eibgrad
Realize that as written, that script will only function as a firewall-start script, since only then will it be passed the WAN's network interface name as a command-line argument ($1) and properly initialize the WAN_IF variable. If you try to execute it from ssh, that's why the rule is producing an error (the fact it refers to REJECT is misleading).
If you want to use that script both from ssh and as a firewall-start script, the following would be better, since if the command-line argument is missing, it grabs it from nvram.
#!/bin/sh
WAN_IF="$([ $1 ] && echo $1 || echo $(nvram get wan0_ifname))"
iptables -I FORWARD -o $WAN_IF -j REJECT
Onilaq
#!/bin/sh
Okay, it worked as intended.
Thank you again for the support, the thread can be closed.
