Lan to Wan connection doesn't work , need help.
In the technicolors main settings there is the "Internet Access" section which is the dsl's sync settings as stated before DHCP routed mode,PPPoE routed mode,Fixed IP mode etc.... It just let you disable this entirely which i did and it leaves a message of "PPP disabled" , then i used my PPPoe codes on the asus router and it just worked.
