LAN/wifi ping times are between 4ms-9ms
Asus9
RT-AC68U , My pings times on the Lan are between 4ms-9ms and wifi also.
I have disabled the wifi radios thinking it was that and that didn't work.
So i hooked up only my pc and printer on the router and still 4ms-9ms..
I don't think this is normal, what should I do?
Ping times to / between what devices?
Check your Ethernet cables, swap them just to be sure.
Make sure jumbo frames are disabled.
The fastest possible RTT for a 9kbyte jumbo ethernet packet on a 100mbit connection is ~1.5ms.
