Latest Firmware and Linksys SPA3102 VOIP
souwalker2
Hi
Happy New Year everyone.
Have been using this VOIP ATA for a few years with Cable Modem and no problems. Recently I got a new router Asus N66U with the Asus firmware and I have no issues too.
Today I updated with the Merlin firmware. The ATA is setup as DHCP and is assigned an IP address. I can see via the N66U web interface that it picked up the ATA and an IP assigned.
Lights on the ATA is green for the Power and green for the Internet. I am pretty sure that the Phone light should be green too, meaning all 3 of those lights should be green when not in use and in the on position. I am certain on this. Am I correct?
If I use the home phone, then the Phone light and the Line lights flashes green.
I am quite certain in the idle mode, the power, Internet and the Phone lights should all be green.
Appreciate your help.
This question is more for Cisco experts. If your ATA is anything like mine (I have an SPA112), there should be a web interface that will give you detailed status information. You'll see if it properly registers or not.
