Layer 2 switch won't forward traffic
dellpe
I have a very simple question - How to get my WS-C2960S-24TS-L switch to forward layer 2 VLAN traffic across a trunk port without a SVI or ip routing configured. I have a Router set as a VTP server, and a switch set as a VTP client connected over a channel-group dot1q trunk link. The switch has no ip routing configured and no SVI. It has received the VLAN info from the router and I have assigned a switchport into a VLAN and added a host, I gave the host a static IP in that VLAN subnet and cant ping the default gateway for that VLAN on the router.
I would post my config but I don't think that is the issue, I think I am missing a core concept here. I have made sure all links are up and double checked everything from that perspective.
post your configuration
I think there is a need that you post your configuration. Then I would know more.
