LG NAS N2R1 (older NAS)
estrichleger
Got a problem with the N1R2 NAS from LG. I tried to install the hdd via enclosure mode but the only thing I get is Netboot. I used my XP VM to connect to the NAS and tried the new firmware to install. That works flawlessly but after the reboot I get boot fail. I cannot get to the webinterface to install the older 2660 firmware. Is there a way to get the NAS to work again.
Is there a way to get the UBoot Update file to the NAS without the webinterface? I think thats were the cookie crumbles here.
I know it is an older one but the files here are my Documents and scans.
Probably using EXT and windows won't be able to read it. Use Linux instead.
As for the NAS itself... If you can figure out the IP either SSH / telnet or SCP should work for copying the file over to it either by IP or plugging a USB drive into the back if there's a port for it and copying from there.
I dont have any files for that NAS. Itsoould go to enclosure mode when you push two buttons on the front of the nas. And thats what it doesnt do anymore all I get is NEtboot.
Oh, well that's different from what I perceived.
Does it work in nas mode or do anything different if you don't press the buttons?
How many disks do you have in it?
How is the drive formatted?
What's the drive size?
Is the drive new?
Seeing reviews from 2010 though means I wouldn't put much effort into recovering it and would be looking for a replacement. If you don't need network availability a SATA/USB cable would work as the least expensive option. If you have multiple drives a DAS would be an option and 4-5 bay options are about $150.
Ah, OK.
Well normal is that you push two buttons on the frontpanel and it should go to "Enclosure Mode" in which the NAS prepares the hdds for usage. But in my NAS I get Netboot and then I can flash the newer OS onto it. After that had been done the NAS rebootsa and gives me "Boot Fail". Thats the status I'm at the moment and I do not know how to pass this error.
Sounds like the update bricked it. Netboot to me sounds like pxe boot where it's possibly able to pull an image form the network and boot from that. There might be a way to recover it using a terminal and console connection. There also might be a way to trigger the update form a USB drive as well. Id contact LG for ideas.
Is the drive new?
Hey Tech Junky, I am in a similar situation but my NAS is intact. But can only access the drives through a mounted connection: /mnt/disk/volume1/service/DLNA my web connection fails or in my current state of using Windows 10 and 11. Telling me my credentials are wrong! is this an OS issue? And can I access it with an older OS? I just want my data :) I can only access some data through the /mnt/ path. Thanks
ddaenen1 Time for a new DIY NAS DIY 4
