Linksys wrt1900ac range.
karun.rox.09
Folks, i buy this router b'coz of its range bt I cannot get wifi signal after 2 room. Which is approximately 15 feet away from router. Cn u suggest wat may b the reason. I asked wid customer care he said jst install router manually.
Double check the antennas are fully screwed on.
Have different SSID's for the 2.4Ghz and 5Ghz.
  • 2.4Ghz slow but longer range
  • 5Ghz super fast but short range
Broken keyboard?
If you have an inSSIDer 4 or similar, try using it to survey your WiFi environment and improve your situation.
There's a new firmware for the wrt1900AC you should upgrade to. It includes some bug fixes.
