Hi guys.
*My mother died, I am badly coping, the internet and gaming are a real crutch for me. I bought this router with the hope of getting improved wifi.*
have just purchased a asus rt-ax82U.I am in UK and my current ISP router is Technicolour router dwa0120 from Shell. I plugged my asus rt-ax82U directly into into the ISP router, using the included Ethernet cable. I have not really been able to ascertain the range of my Technicolor router, so I cannot comment on the supposed range differential, but I thought that the ASUS router would have a higher/stronger range.
Yet it would appear this is not the case at all. I live in an apartment. I am a "L-shape" away from the router. I thought naively, that using 2.4 GHz and an upgraded router would be sufficient to help improve range and speed. So far, seen absolutely no to little improvement.
I am not a networking guru at all. My ISP router requires a modem (I think? It plugs into a phone socket on the wall) for it to connect to the internet. From there, I have connected my ASUS RT-AX82U to my ISP router, using an Ethernet cable. My ISP router and ASUS router, are both in the same room.
I have a wifi extender (its buggy, I can't resync it, only works with my ISP router). I am getting better broadband with that, and that cost £15 ($20-$25) versus the £200 Ive spent on the ASUS router.
By no means a scientific methodology of analysis, but I looked at my PS5, connected to the ASUS router network. 1-3 Mbs is the max I'll get for downloading. Wifi signal strength sits at 40% (one bar). Using my WIFI extender of my ISP network, Im getting roughly the same, with 100% signal.
My ISP router isnt detectable at all by my PS5, but it is by my laptop, which is odd given they are both together, in the same room, directly beside each other. its taking me roughly 1 hr for 1 GB of data.
I have heard wonder stories of people who have used the asus router, without mesh networking capability and have had consistent and strong traffic. I have not seen any increase of note in either range, or traffic. What am I doing wrong?
