Phantomski
encountering really odd DNS issue after dirty-installing 386.9 fw (upgrade from 386.7-2).
On the previous versions of firmware, I was using
This worked well until fw 386.7-2, but stopped working on 386.9, but strangely only for ethernet devices (WiFi clients work ok), despite same DHCP settings. If I set their config to static instead of DHCP and set DNS manually to my router's IP, the result is the same.
WiFi clients:
Ethernet Clients:
I have tried restarting the router, restarting the clients, various settings for DNS Director and enabling/disabling it, restarting dnsmasq, nothing helps.
Current relevant settings:
/jffs/configs/dnsmasq.conf.add for local network name resolution in the form of address=/[server.domain]/[ip]. The domain itself is .home, so shouldn't create any conflicts.This worked well until fw 386.7-2, but stopped working on 386.9, but strangely only for ethernet devices (WiFi clients work ok), despite same DHCP settings. If I set their config to static instead of DHCP and set DNS manually to my router's IP, the result is the same.
WiFi clients:
❯ nslookup router.home
Server: 192.168.1.1
Address: 192.168.1.1#53
Ethernet Clients:
❯ nslookup router.home 192.168.1.1
Server: 192.168.1.1
** server can't find router.home: NXDOMAIN
- LAN / LAN IP / RT-AC88U's Domain Name: home
- LAN / DHCP Server / DNS and WINS Server Setting: DNS Server 1 and 2 blank, Advertise router's IP in addition to user-specified DNS: Yes
- DNS Director: OFF
- Tools / Other Settings: Wan: Use local caching DNS server as system resolver (default: No): Yes (using because it made local queries much quicker)
- WAN / Internet Connection / WAN DNS Setting: Forward local domain queries to upstream DNS: No, Enable DNS Rebind protection: No
- Using DNSSEC, DoT (Quad9), Diversion
