Log flood by dnsmasq
lawk
My log is constantly being flooded with this message, once a second:
dnsmasq[22041]: LOUD WARNING: use --bind-dynamic rather than --bind-interfaces to avoid DNS amplification attacks via these interface(s)
dnsmasq[22041]: LOUD WARNING: listening on 213.XXX.218.XX may accept requests via interfaces other than eth0
I only edited my public ipv4 for privacy. Any idea what could be causing it?
Router model and firmware please.
RT-AX88U Pro, 3.0.0.6.102_21514
I think I found the cause:
it happens when "Advertise router's IP in addition to user-specified DNS" is enabled.
It still does it with that option disabled.
I tried something else now, let the WAN default DNS from ISP as enabled.
for now the messages are gone.
So this keeps happening. After all.
dnsmasq is warning you that it is listening on an interface with a public IP. Whats the output of this command, run on the router over SSH?
grep -E "bind|interface" /etc/dnsmasq.conf
I don’t think anyone knows what the new Asus source code looks like yet, but this seems unusual, compared to past releases.
My config from Merlin 388 firmware shows:
# grep -E "bind|interface" /etc/dnsmasq.conf
bind-dynamic
interface=br0
interface=pptp*
no-dhcp-interface=pptp*
interface=br1
interface=br2
That’s pretty wild that it explicitly adds the wan interface. Do you run a IPsec VPN server / Instant Guard?
I did run IPSec but turned it off, I run Wireguard.
I will try with wireguard turned off.
M dnsmasq issue ASUSWRT - Official 12
