Log "unsolicited" inbound connection attempts?
JaimeZX
Either blocked by Skynet or not... is there an easy way to dump these things into a separate log file? I'm just curious what kind of traffic I'm getting. Or would it be totally overwhelming?
What do you guys think?
If you're referring to inbound connection attempts even when there isn't a service running on that port then you could set "Logged packets type" to Dropped (or Both). And yes it will be overwhelming in my experience.
If you're talking about connection attempts to services that you have exposed to the internet... well that should really only be a VPN, and that will log failed connection attempts anyway.
Yep. I was referring to all failed inbound connections. Ridonk I guess... Thanks.
All failed attempts can be seen by skynet when all settings are enabled. You see blocks, you see invalid packets...:D
You could always save the log file and search it.
These days I got so much log that I decided to disable debug mode unless I have issue with some websites and need further investigation.
Lol.
