Login to AC68P via wireless
dougan
Just bought the ac68p, and while on the home network it seems to allow login to the gui via wireless. Is that default? And is there an option to change it?
Previous routers I have had have an option to allow or reject login from wireless, and usually defaulted to login via wired only.
I have a ac68U, and as long as I know there is no option for that in the gui.
That said, look in the section Miscellaneous of the Administration menu if you want to strengthen the security.
