Looking for a dual wan router with Gigibit
Bahamut_Launch
I recently moved, and found that I wasn't getting the speeds I was used to on the LAN. I realized I forgot that the Router effects the speed of both the Wan and the LAN. (opps >_<)
Anyway, I purchased a Linksys RV082, and a DSL 7 Mb line as well as a 1.5 T1. The RV082 is a 10/100 router.
I'm pretty sure my Lan Speeds would improve again if I had a Gigibit router.
My question is:
Is there a good Dual Wan Gigibit Router in the same price rage as the Linksys RV082? If I need to spend more I will however.
Also I'm about to look this up, but I have a NSA 240 SonicWall Router. Does that have Dual Wan Feature?
Thanks!
Just buy a gigabit switch and connect it to a router LAN port.
Hmm, I do have a gigbit switch connected to the router.
...Any other ideas why I may not be getting gigbit speed. (also how do I test that?)
Your computers need to have Gigabit LAN ports, of course.
You can check speed with LAN SpeedTest or doing any large file copy from machine to machine.
A Looking for a 10Gbps wired router Routers 39
G No WAN with Bell 4000 passthrough Routers 9
