Looking for simple plug and play AP's for my fathers Cox XB7
talisman2208
What would you recommend that's easy to set up that basically acts as a mesh network that he can conntect to this XB7? I'll be troubleshooting from out of state so I can't have it be too difficult. Does anything exist?
Google Nest Wifi (Pro) and Amazon eero (Pro) are good set and forget home "mesh" systems. Better than most, Easy Button solution.
So you need them to be cloud managed, correct?
I have Aruba InstantOn at home and you can get 2 access points and create a mesh network in 10 minutes. Later you can add more AP to this mesh network and control in via Web and App remotely via their free cloud.
I believe the new Cisco 150ax APs allow iPhone access to the wireless APs. I originally had it setup but then I deleted it as I figured I did not need it.
