Merlin 380.58 @ RT-AC68U VPN issues..
gekko44
I'm trying to set up OpenVPN servers and while TAP connection works perfectly I can't figure out what's wrong with TUN connection.
Connection log:
Wed Mar 30 14:12:35 2016 OpenVPN 2.3.10 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on Feb 1 2016
Wed Mar 30 14:12:35 2016 Windows version 6.1 (Windows 7)
Wed Mar 30 14:12:35 2016 library versions: OpenSSL 1.0.1r 28 Jan 2016, LZO 2.09
Enter Management Password:
Wed Mar 30 14:12:43 2016 UDPv4 link local: [undef]
Wed Mar 30 14:12:43 2016 UDPv4 link remote: [AF_INET]xx.xx.xx.xx:1194
Wed Mar 30 14:12:43 2016 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Wed Mar 30 14:12:43 2016 VERIFY ERROR: depth=1, error=self signed certificate in certificate chain: C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC68U, [email protected]
Wed Mar 30 14:12:43 2016 TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
Wed Mar 30 14:12:43 2016 TLS Error: TLS object -> incoming plaintext read error
Wed Mar 30 14:12:43 2016 TLS Error: TLS handshake failed
Wed Mar 30 14:12:43 2016 SIGUSR1[soft,tls-error] received, process restarting
Any ideas ?
thank for reply.
Unfortunately ".opvn" file couldn't be created when "tls-client" option existed in custom configuration. Only after removing it file was created, but still can't connect - below log:
Thu Mar 31 09:33:00 2016 OpenVPN 2.3.10 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on Feb 1 2016
Thu Mar 31 09:33:00 2016 Windows version 6.1 (Windows 7)
Thu Mar 31 09:33:00 2016 library versions: OpenSSL 1.0.1r 28 Jan 2016, LZO 2.09
Thu Mar 31 09:33:07 2016 UDPv4 link local: [undef]
Thu Mar 31 09:33:07 2016 UDPv4 link remote: [AF_INET]xx.xx.xx.xx:1196
Thu Mar 31 09:33:08 2016 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Thu Mar 31 09:33:08 2016 VERIFY ERROR: depth=0, error=unable to get local issuer certificate: C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC68U, [email protected]
Thu Mar 31 09:33:08 2016 TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
Thu Mar 31 09:33:08 2016 TLS Error: TLS object -> incoming plaintext read error
Thu Mar 31 09:33:08 2016 TLS Error: TLS handshake failed
Thu Mar 31 09:33:08 2016 SIGUSR1[soft,tls-error] received, process restarting
bump...anyone ? :(
Its not the same when you are configuring a server as it is a client to a server.
the guide i pasted was for a client.
Try general instead of advanced settings. put a username and password and
it gives you a .ovpn file that you will import into a VPN client so you can connect to the tunnel
its not hard.
Don't over complicate yourself :)
