Currently using Asus RT-AC68U as main router (radio turned off to lower temps since it's in the bomb shelter) and hardcabled to several Access Points (RT-AC1200Gx2, RT-AC87, another RT-AC68 all in AP mode).
Use case:
Upgrade to a wifi Mesh system that supports Guest Network (users on guest SSID isolated from main network).
Better coverage/no connect reconnect when roaming between access points. Easier user admin.
Guest network is a key requirement. Current setup has only AP RT-AC87 & AP RT-AC68 broadcasting guest network SSID. Guest network isolation only works properly if you run a specific script on Merlin firmware. Seems pervasive across all Asus Access Points (or routers in AP mode).
Options:
Option 1) Replace everything with a mesh router (main node) + satellites (secondary node)
Option 2) Keep main router. Replace all access points with mesh system capable APs.
Option1 is clearly more costly as I've to basically burn the Main node, main router has to be located inside a bomb shelter.
Option2 is best bang for buck i guess if I can get these dang things' Guest Networks to work properly in AP mode.
Choices:
1) Deco M9 3 pack
2) Orbi RBK53 (read that guest network still has bugs? this )
3) Orbi Pros (crazy exp but guest network works for sure)
4) Asus XT8 (Guest IS STILL NOT WORKING properly. my god what are you doing Asus)
https://www.snbforums.com/threads/zenwifi-ax-firmware-bugs.63171/
Anyone has a similar deployment with choices above please do share.
Any ideas are welcome as well.
Thanks in advance!
Use case:
Options:
Choices:
1) Deco M9 3 pack
Thanks in advance!
