Minidlna - force_sort_criteria - sort by file name
swenak
I trying to change force_sort_criteria in Minidlna to sorting by file name, but it not work as I need. I want only to sorting by file name, like in Windows, not tags, or any other files informations. It is, because I use same files source on multiple devices and some devices (and apps) can sort only by file name and I want same sorting on all devices.
I use Merlin 380.68.
Thanks.
Sorting should usually be handled by the client device rather than the DLNA server.
My DLNA device cannot sorting by filename (Yamaha WXA-50) :-( This is, why I tryng to force it. And some other devices have same problem (like Panasonic TV).
force_sort_criteria="+dc:title"
That's was first, what I tested, but it not work.
Yes, I restart minidlna and changing of line changing, how client showing files, so, it works.
Now I have this in file:
root_container=B
db_dir=/jffs/minidlna/db
log_dir=/jffs/minidlna/log
#force_sort_criteria=+upnp:class,+upnp:originalTrackNumber,+dc:title
force_sort_criteria=+dc:title
Sorting by file name is undocumented and I don't know if it's supported at all. Your best bet is to read the source or use your google-fu to see if someone else has found a way in making it work
