Missing router command section
repeater
Hey Fellas,
I have a new 86u with latest Merlin. Had some NTFS issues that I solved with EXT4 (we will see). I was poking around and noticed that I can't find the one time command that was there before. It had a disclamore not to run repeating commands or something.
I looked at everywhere. I think it was under admin. storage it would disappear.
Am I missing something? I'm not actually sure what it was used for.
The command page has been removed a long time ago. For security reasons. Enable SSH and use an SSH client to access the router.
Weird it was there for the first couple of days after install. I have had the router a week and flashed it day two. Strange it was there then gone.
I agree - That screen shouldn't be there...
it's from the upstream from a long time ago and was purged - wonder if there was a regression in the code base - might not be a bad idea to deep spider the http pages and see what's there..
Even if you directly access the page by its URL, httpd no longer accepts to run arbitrary commands, so the page wouldn't work.
