Mochabin - Interesting kickstarter
john9527
Part of the Furniture
Already has an OpenWrt support branch....
Commit went into master the other day...
mvebu: add Globalscale MOCHAbin
Globalscale MOCHAbin is a Armada 7040 based development board.
Specifications:
* Armada 7040 Quad core ARMv8 Cortex A-72 @ 1.4GHz
* 2 / 4 / 8 GB of DDR4 DRAM
* 16 GB eMMC
* 4MB SPI-NOR (Bootloader)
* 1x M.2-2280 B-key socket (for SSD expansion, SATA3 only)
* 1x M.2-2250 B-key socket (for modems, USB2.0 and I2C only)
* 1x Mini-PCIe 3.0 (x1, USB2.0 and I2C)
* 1x SATA 7+15 socket (SATA3)
* 1x 16-pin (2×8) MikroBus Connector
* 1x SIM card slot (Connected to the mini-PCIe and both M.2 slots)
* 2x USB3.0 Type-A ports via SMSC USB5434B hub
* Cortex 2x5 JTAG
* microUSB port for UART (PL2303GL/PL2303SA onboard)
* 1x 10G SFP+
* 1x 1G SFP (Connected to 88E1512 PHY)
* 1x 1G RJ45 with PoE PD (Connected to 88E1512 PHY)
* 4x 1G RJ45 ports via Topaz 88E6141 switch
* RTC with battery holder (SoC provided, requires CR2032 battery)
* 1x 12V DC IN
* 1x Power switch
* 1x 12V fan header (3-pin, power only)
* 1x mini-PCIe LED header (2x0.1" pins)
* 1x M.2-2280 LED header (2x0.1" pins)
* 6x Bootstrap jumpers
* 1x Power LED (Green)
* 3x Tri-color RGB LEDs (Controllable)
* 1x Microchip ATECC608B secure element
Note that 1G SFP and 1G WAN cannot be used at the same time as they are in
parallel connected to the same PHY.
Mixed opinions on Globalscale Technologies over at CNX Software.
