Moving settings von AC68U to AC86U ?
Rici
After several years of using an Asus AC68U running Merlin I bought the Asus AC86U, and of course will run Merlin on it, too.
Is there a way to transfer all of my settings from my previous to my new router?
Yes, type them in :)
One option is to have 2 browser windows open and copy/paste form one to the other.
Don't save and try to reload a configuration file from one to the other.
Thanks, dosborne.
Of course I wanted to avoid that 100% manual stuff.
My hope was that there is some automation available.
Thanks, dosborne.
If you are patient enough, you might be in luck, eventually.
https://www.snbforums.com/threads/d...cp_hostnames-utility.58957/page-3#post-531114
In the meantime, Xentrk utility is dhcp_staticlist.sh saves redoing all the dhcp manual assignments. I save screenshots of all my essential router settings when I need to do a full nuclear reset.
https://www.snbforums.com/threads/dhcp_staticlist-and-dhcp_hostnames-utility.58957/
