System Error Message
Part of the Furniture
Here i will introduce my current test bench. I will update this thread as things change and include pictures later.
This is how the test will be done as close as possible. Its very much like @thiggins setup but with more test servers and a seperate network for monitoring and control of servers and test device.
[servers]
[1] AMD phenom ii x3 unlocked to x4 and overclocked to 3.2Ghz, 16GB ram,mellanox SFP+ card ,opensuse (software not ready)
[2] Intel x5650 overclocked to 4Ghz, 16GB ECC ram (cant find the other stick),dual SFP+ card, opensuse (software not ready, NIC issue)
[3] AMD piledriver 8 core 4.3Ghz, 32GB ram, Intel server quad port NIC, windows server 2012 (software not ready)
[4] AMD bulldozer 4 core, 8GB ram, Intel server quad port NIC (I350) sun branded, (no OS)
[5] another board for intel x5650 (CPU socket pins bent)
[6] 2x L5520 (cant find on the hp server board where the pins for power button is, really its that difficult)
[7] quad core i7 ivybridge laptop, 12GB ram, aetheros NIC
[8] core2duo, (still in assembly -PSU, HDD)
[9] core2duo thinkpad, (needs assembly from bits.)
[10] core2duo laptop, (no OS)
[e] Prodigit Electronics 2000MU wattmeter
Ofcourse the servers do other tasks while not benchmarking, such as being a server for web, games, media, files and warming up my room. They do have to pull their weight and earn their upkeep.
[software]
Software that is used for testing.
-netdata
-iperf
-apache server (apache bench)
Currently i dont have a clue what i should use, so please write your suggestions
[Testing]
Stuff that is tested.
- ipv4 NAT performance (both hardware acceleration and no hardware acceleration) (64B, 512B,1500B)
- ipv6 static routing performance (both hardware acceleration and no hardware acceleration)
Do suggest more. (64B, 512B,1500B)
- ipv4 NAT with PPPOE (64B, 512B, 1500B)
- apache server file benchmark over ipv4 NAT (100,1K,10K,100K of 10KB, 1MB file)
So out of all the routers i have on hand right now, try to guess which brand will go first
Mikrotik
Ubiquiti
Asus
Zyxel
BT homehub 5A.
Feel free to discuss/criticise
For future tests QoS can be considered but the software to use and router configuration files will need to be made for quicker test setups.
[servers]
[software]
-netdata
-iperf
[Testing]
Mikrotik
Ubiquiti
Asus
Zyxel
BT homehub 5A.
