Any mysterious connections showing in the logs? What is the uptime of the router?
Either way, change the username and the router password.
No mysterious connections that I can notice but maybe this isn't where to look. Also, it had been up a month and a half, bought the 88 on November 1st. I rebooted PC, cable box and the 88 before noticing radios were off. Weird that there isn't anything until last night:
System Log - General Log
May 5 01:05:22 BONDING: option disabled
May 5 01:05:22 ntpd: Started ntpd
Dec 3 10:23:34 ntpd: Initial clock set
Dec 3 10:23:35 rc_service: ntpd_synced 1631:notify_rc restart_diskmon
Dec 3 10:23:35 disk_monitor: Finish
Dec 3 10:23:35 disk_monitor: be idle
Dec 3 10:23:35 miniupnpd[1664]: HTTP listening on port 47037
Dec 3 10:23:35 miniupnpd[1664]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 3 10:23:35 dhcp_client: bound 198.48.235.2/255.255.255.224 via 198.48.235.1 for 124034 seconds.
Dec 3 10:23:36 WAN_Connection: WAN was restored.
Dec 3 10:23:53 kernel: ubi1: attaching mtd10
Dec 3 10:23:53 kernel: ubi1: scanning is finished
Dec 3 10:23:53 kernel: ubi1: attached mtd10 (name "misc1", size 8 MiB)
Dec 3 10:23:53 kernel: ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Dec 3 10:23:53 kernel: ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Dec 3 10:23:53 kernel: ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
Dec 3 10:23:53 kernel: ubi1: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
Dec 3 10:23:53 kernel: ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
Dec 3 10:23:53 kernel: ubi1: max/mean erase counter: 8/3, WL threshold: 4096, image sequence number: 696890461
Dec 3 10:23:53 kernel: ubi1: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
Dec 3 10:23:53 kernel: ubi1: background thread "ubi_bgt1d" started, PID 1920
Dec 3 10:23:54 kernel: ubi: mtd10 is already attached to ubi1
Dec 3 10:23:54 kernel: UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 1964
Dec 3 10:23:54 kernel: UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "nvram"
Dec 3 10:23:54 kernel: UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Dec 3 10:23:54 kernel: UBIFS (ubi1:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
Dec 3 10:23:54 kernel: UBIFS (ubi1:0): reserved for root: 0 bytes (0 KiB)
Dec 3 10:23:54 kernel: UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID F81C8FF9-1B06-40EB-A05C-64D9AAF47331, small LPT model
Dec 3 10:24:01 kernel: random: nonblocking pool is initialized
Dec 3 10:24:01 httpd: Succeed to init SSL certificate...80
Dec 3 10:24:02 rc_service: cfg_server 1301:notify_rc start_bsd
Dec 3 10:24:11 crond[1197]: time disparity of 1358538 minutes detected
Dec 3 10:24:40 kernel: bcm_i2c: bus 0: Failed to detect SFP: 100 retries exhausted
Dec 3 10:32:43 rc_service: httpd 1198:notify_rc restart_wireless
Dec 3 10:32:44 kernel: UBIFS (ubi1:0): un-mount UBI device 1
Dec 3 10:32:44 kernel: UBIFS (ubi1:0): background thread "ubifs_bgt1_0" stops
Dec 3 10:32:44 kernel: ubi1: detaching mtd10
Dec 3 10:32:44 kernel: ubi1: mtd10 is detached
Dec 3 10:32:45 kernel: ubi1: attaching mtd10
Dec 3 10:32:46 kernel: ubi1: scanning is finished
Dec 3 10:32:46 kernel: ubi1: attached mtd10 (name "misc1", size 8 MiB)
Dec 3 10:32:46 kernel: ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Dec 3 10:32:46 kernel: ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Dec 3 10:32:46 kernel: ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
Dec 3 10:32:46 kernel: ubi1: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
Dec 3 10:32:46 kernel: ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
Dec 3 10:32:46 kernel: ubi1: max/mean erase counter: 8/3, WL threshold: 4096, image sequence number: 696890461
Dec 3 10:32:46 kernel: ubi1: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
Dec 3 10:32:46 kernel: ubi1: background thread "ubi_bgt1d" started, PID 2938
Dec 3 10:32:47 kernel: UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 2957
Dec 3 10:32:47 kernel: UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "nvram"
Dec 3 10:32:47 kernel: UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Dec 3 10:32:47 kernel: UBIFS (ubi1:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
Dec 3 10:32:47 kernel: UBIFS (ubi1:0): reserved for root: 0 bytes (0 KiB)
Dec 3 10:32:47 kernel: UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID F81C8FF9-1B06-40EB-A05C-64D9AAF47331, small LPT model
Dec 3 10:32:47 kernel: UBIFS (ubi1:0): un-mount UBI device 1
Dec 3 10:32:47 kernel: UBIFS (ubi1:0): background thread "ubifs_bgt1_0" stops
Dec 3 10:32:47 kernel: ubi1: detaching mtd10
Dec 3 10:32:47 kernel: ubi1: mtd10 is detached
Dec 3 10:32:52 acsd: eth7: Selecting 5g band ACS policy
Dec 3 10:32:54 acsd: eth7: selected channel spec: 0xe22a (44/80)
Dec 3 10:32:54 acsd: eth7: Adjusted channel spec: 0xe22a (44/80)
Dec 3 10:32:54 acsd: acs_set_chspec: 0xe22a (44/80) for reason APCS_INIT
Dec 3 10:32:59 WLCEVENTD: Auth 70:81:EB:BB:70:EA
Dec 3 10:32:59 WLCEVENTD: Assoc 70:81:EB:BB:70:EA
Dec 3 10:32:59 WLCEVENTD: Auth B2:BD:B6:8B
4:22
