myQ Garage Opener "Offline" on ZenWiFi ET9 Guest Network
sagarr
I’m having a specific issue with my myQ Garage Door Opener and my Asus Zenwifi Et9 AiMesh system. I have a two-node setup with an Ethernet backhaul between them.
My garage opener is physically much closer to Node 2 (signal strength is a strong -40dBm). However, when it connects to Node 2's guest network, it shows as "Offline" in the myQ app and cannot reach the internet.
Strangely, if it connects to Node 1 (the main router), it works perfectly fine, even though the signal is much weaker (-70dBm).
The Setup:
  • Hardware: 2x ASUS ZenWiFi ET9
  • Backhaul: Ethernet cable connecting Node 1 (Main) and Node 2.
  • Network: Dedicated 2.4 GHz Guest Network for IoT devices.
  • Authentication mode : WPA/WPA2
  • Status: Node 2 shows "Great" connection to Node 1 in the app.
Visual Diagram of the Issue:
r/HomeNetworking - myQ Garage Opener Offline on ZenWiFi ET9 Guest Network
What I've tried:
  • Rebooting both nodes.
  • Verifying that the myQ is reachable from the app (online) when forced to Node 1.
  • Use many other IoT devices (google home, tplink bulb and switches) connected to node2 and the same 2.4ghz guest network. They work fine.
It seems like Node 2 is broadcasting the Guest SSID but isn't actually routing the traffic to the internet over the ethernet backhaul only for 1 device. Has anyone encountered this "Guest Network Black Hole" on secondary ZenWiFi nodes? Is there a specific sync setting I'm missing?
I have a MyQ opener. It is on a guest WIFI and I have seen the device connect to either the node or router. Use just WPA2-Personal, 20 MHz only on the 2.4 GHz, Do not enable Ethernet Backhaul in the AiMesh settings but Auto (I have better success with Auto). Also use a simple guest network SSID of no more than 8 alpha/numeric characters but no special characters or spaces. Same with the WIFI password for the guest network.
