N66u Asuswrt-Merlin 378.52 Can not access AirPrint From Access Point
vwsplitty1980
Good Morning,
As the title says i have a working N66u with 378.52, connected to this via wifi i have a Brother 3140CW printer. If i connect any idevice to either of the 2.4ghz or 5ghz wifi signals the airprint feature works without fault. The problem i have is that from one of my LAN ports i run a gigabit cat6 up to a gigabit network switch in the back bedroom, to that switch via a LAN port i have a BT Homehub 5 that i use solely as a wireless access point. If i connect to either the 2.4 or 5 ghz wireless signal on the home hub 5 i can not get the airprint feature to work. Now im guessing this has something to do with Bonjour protocol not be passed along but other than that im not really sure?
just like to add not had this set up before and the n66u is working. the access point is a new addition.
