Need command to create swap file
Jay Culley
Hi. Please excuse my noobness but I am not having much luck creating a swap file. Here is what I have done:
1: Asus RT-AC5300 running Asuswrt-merlin 380.64_1, jffs enabled, only 1 script for logging vsftpd
2: The USB 3.0 port has a 1 TB NTFS drive shared with Samba for music, movies, etc /dev/sdb1 mounted on /tmp/mnt/Exthdd
3: The USB 2 port has an inexpensive Lexar 32GB thumdrive
primary partition /dev/sda2 is 27GB mounted on /tmp/mnt/lex. Latest Entware installed
4: Also on the USB2 Lexar thumbdrive is a logical partition /dev/sda5 size 1 GB formatted Linux Swap, not mounted, no files.
So I guess I need to add an entry to fstab, then run mkswap and swapon? I need the commands with the correct syntax for the BusyBox os that Merlin runs. I am assuming my swap partition of 1GB is fine since the AC5300 has 500MB of RAM, is that correct?
thanks
jay
You need to create the partition first ex: /dev/sda5.
# mkswap /dev/sda5
# swapon /dev/sda5
Then edit fstab:
/dev/sda5 none swap sw 0 0
or simply run "swapon /dev/sda5" command at boot script.
Yes, 1GB of swap should be fine.
so, /etc/fstab was empty, now it has one line: /dev/sda5 none swap sw 0 0
the other 2 commands looked good
user@5300:/proc# mkswap /dev/sda5
Setting up swapspace version 1, size = 1047523328 bytes
UUID=17a5db57-07b2-4b98-bb72-cb6c34e0e769
user@5300:/proc# swapon /dev/sda5
user@5300:/proc#
booting...
In order to check if it's working:
# free
did not work. /proc/swaps has nothing and running the top command list no swap at the top. Should this go in /jffs/scripts in services-start or post-mount or in a conf file in /jffs/configs?
free
total used free shared buffers
Mem: 515308 125684 389624 0 536
-/+ buffers: 125148 390160
Swap: 0 0 0
It didn't worked because the info you added to /etc/fstab was lost after a reboot, you need to add it there or run the swapon command via boot-script.
You will see it working if you manually run this:
# swapon /dev/sda5
# free
OK, good to go! I ran swapon /dev/sda5 and it is now running
free
Mem: 515308 159664 355644 0 3380
-/+ buffers: 156284 359024
Swap: 1022972 0 1022972
I added the swapon command to /jffs/scripts/post-config so it will fire off on the next boot
Thanks @hggomes !!
You are very welcome Jay.
