Need help with softflowd
vlord
I have Merlin's .354.29 build and am having trouble getting softflowd to run as a daemon. I can get it to run in debug form but not otherwise. Any suggestions? Ultimately I'll be forwarding the data to a netflow analyzer but need help with baby steps.
admin@RT-AC66R:/tmp/home/root/fprobe# ifconfig
br0        Link encap:Ethernet  HWaddr 50:46:5D:D1:81:A0
           inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
           RX packets:3242661 errors:0 dropped:0 overruns:0 frame:0
           TX packets:1689661 errors:0 dropped:0 overruns:0 carrier:0
           collisions:0 txqueuelen:0
           RX bytes:481452974 (459.1 MiB)  TX bytes:125457441 (119.6 MiB)
eth0       Link encap:Ethernet  HWaddr 50:46:5D:D1:81:A0
           inet addr:192.168.212.104  Bcast:192.168.212.255  Mask:255.255.255.0
           RX packets:1861914 errors:0 dropped:0 overruns:0 frame:0
           TX packets:3328106 errors:0 dropped:0 overruns:0 carrier:0
           collisions:0 txqueuelen:1000
           RX bytes:353118178 (336.7 MiB)  TX bytes:567393875 (541.1 MiB)
           Interrupt:4 Base address:0x2000
eth1       Link encap:Ethernet  HWaddr 50:46:5D:D1:81:A0
           RX packets:0 errors:0 dropped:0 overruns:0 frame:105496
           TX packets:0 errors:1 dropped:0 overruns:0 carrier:0
           RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
           Interrupt:3 Base address:0x8000
eth2       Link encap:Ethernet  HWaddr 50:46:5D:D1:81:A4
           RX packets:3267593 errors:0 dropped:0 overruns:0 frame:25574
           TX packets:1380194 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:496330478 (473.3 MiB)  TX bytes:257803254 (245.8 MiB)
           Interrupt:5 Base address:0x8000
lo         Link encap:Local Loopback
           inet addr:127.0.0.1  Mask:255.0.0.0
           UP LOOPBACK RUNNING MULTICAST  MTU:16436  Metric:1
           RX packets:1009 errors:0 dropped:0 overruns:0 frame:0
           TX packets:1009 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:158047 (154.3 KiB)  TX bytes:158047 (154.3 KiB)
vlan1      Link encap:Ethernet  HWaddr 50:46:5D:D1:81:A0
           RX packets:49527 errors:0 dropped:0 overruns:0 frame:0
           TX packets:45398 errors:0 dropped:0 overruns:0 carrier:0
           RX bytes:48759144 (46.5 MiB)  TX bytes:26481101 (25.2 MiB)
Run in debug mode:
admin@RT-AC66R:/tmp/home/root/fprobe# softflowd -i eth0 -v 9 -D
softflowd v0.9.8 starting data collection
ADD FLOW seq:1 [184.168.51.1]:80 <> [192.168.212.104]:59136 proto:6
ADD FLOW seq:2 [192.168.212.36]:1778 <> [255.255.255.255]:1778 proto:17
ADD FLOW seq:3 [192.168.212.136]:56497 <> [192.168.212.255]:8612 proto:17
ADD FLOW seq:4 [192.168.212.136]:52585 <> [224.0.0.1]:8612 proto:17
ADD FLOW seq:5 [192.168.212.5]:53 <> [192.168.212.104]:38426 proto:17
ADD FLOW seq:6 [192.168.212.6]:53 <> [192.168.212.104]:38426 proto:17
ADD FLOW seq:7 [192.168.212.1]:53 <> [192.168.212.104]:38426 proto:17
ADD FLOW seq:8 [192.168.212.5]:771 <> [192.168.212.104]:0 proto:1
Run as daemon and check for process running:
admin@RT-AC66R:/tmp/home/root/fprobe# ps |grep softflowd
 6442 admin     1416 S    grep softflowd
I had the same problem so I cheated :)
just run it with -d and background the task with &
so
>softflowd -i br0 -n 192.168.1.xx:2055 -m 1600 -d &
The way I actually use it is at boot time by creating the file /opt/etc/init.d/S29softflow with the following contents;
#!/bin/sh
ENABLED=yes
PROCS=softflowd
ARGS="-i br0 -n 192.168.1.xx:2055 -m 16000 -d"
PREARGS=""
DESC=$PROCS
PATH=/opt/sbin:/opt/bin:/opt/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
. /opt/etc/init.d/rc.func
I noticed that you aren't calling out the netflow version but my real question is the call at the end of your script for rc.func - what is that doing? Doesn't exist on my router.
Stumbled across this thread while googling what sounds like the same issue you had - can't get softflowd to run on it's own without using the '-d' switch. Who knows if you're still on the forums.....and it's been years now, but did you end up getting this working?
