Netflix Detects My VPN Only On TV
Khantahr
I have a RT-AX88U running the latest Merlin. I have the router configured to connect to ProtonVPN and route traffic to it with the VPN Director. I have a PiHole that the router forces all DNS request to go to, and the PiHole, uses Unbound for most things, but will direct Netflix related domains to use ProtonVPN's DNS.
Using this setup has Netflix working on my computers using a browser, on my Android phone using the Netflix app, and my Chromecast while casting from my phone. On my LG SmartTV though, it gives me the usual "you seem to be using a VPN" error message. I can't figure out why it's detecting it on the TV. I've attached screens of some configuration settings too. Console screenshot is the dnsmasq configuration to use the ProtonVPN DNS for the Netflix related domains.
I know the TV app is hard coded to use Google's DNS server 8.8.8.8, so maybe it's related to that somehow? I can't figure it out, any ideas?
Not sure why you didn't post this in the Merlin forum. You'd be more likely to get relevant help. I only noticed it by accident.
Based on what you posted, it would seem to be correct. Yes, the TV using a hard-coded DNS of 8.8.8.8 would normally be a problem, but that should be corrected by the global DNS filter.
BTW, the rule for 192.168.1.10 is superfluous since it's already covered by the rule below it, 192.168.1.0/24 (unless OVPN3 is a mistake, and like 192.168.1.3, it was meant to use OVPN2).
You might be a good candidate for my DNS monitoring utility, just as a sanity check.
Given the complexity of DNS configuration options, sometimes things don't behave as expected.
P.S. What version of Merlin? v386.5 was just released Wed., so I want to be sure whether it's 386.4 or 386.5.
I wasn't really sure where the best place to post would be. If it could be moved there that would be great. I am on Merlin 386.5. The rule for .10 is superfluous as it's set up right now, but originally I was going to have it aimed at a different one, so I just left it there until I make a final decision on it.
I have looked at the nf_conntrack contents as you talk about in that tutorial, and I see the request/response from the TV. I'm wondering if the TV sees something fishy in the response?
That connection shows the global DNS filter in action. The client is attempting to access 8.8.8.8 as you suggested earlier. But it's being redirected to the router's DNS proxy (DNSMasq), which in turn has forwarded it to Unbound @ 192.168.1.2. So at least for that one particular connection, it presumably wasn't attempting to access any of the server directives you have specified in the DNSMasq config file.
That's why it would better to monitor *all* the DNS traffic w/ the script than to randomly extract just one connection from connection tracking.
Might be going thru a proxy server - remember that Netflix detects VPN's due to a lot of traffic going thru few IP's...
T VPN tunnel active but no ping Other LAN and WAN 2
