John in LB
This might be obvious to some of you; however, thought I would mention the following:
I have been trying to extend the range of my EX6200 for sometime (both between extender and the modem / router and the end devices.) I tried all of the various suggestions on the web, including replacing the 5 dBi antennas with 8 dBi units (longer version).
While all of my efforts resulted in some improvements, the connections were unstable and would drop out every few hours / days.
Up to now, I always had the unit in the stand, in a vertical position - for space saving reasons.
In reviewing the owner's manual, I noticed a comment that placing the unit horizontally instead of vertically may offer better performance. When I did this - I obtained a much better / more stable connection all around! I was quite surprised by this result... I can only speculate that in the vertical position, the EX6200 body is blocking part of the signal.
Please note: Both antennas are vertically oriented. Also, I am only using / interested in the 2.4 GHz band.
Below is an excerpt from the manual - page 16. Note the last sentence of paragraph #2.
