Netgear Nighthawk AC3200 vs Linksys AC5400 & Using with Verizon service
parth1998
I haven't posted here before so I dont know if this is the right place for these questions, if not please let me know and I can move it.
My first questions is: which router is better (disregarding price), the Netgear Nighthawk AC3200 or theLinksys AC5400?
Links for each router are as follows:
Netgear Nighthawk AC3200: https://www.amazon.com/dp/B00KWHMR6G/?tag=snbforums-20
Linksys AC5400: https://www.amazon.com/dp/B017NT8Q24/?tag=snbforums-20
I belive the answer is the Linksys but I would like to confirm.
The second question is using the better of the routers with Verizon. I know there are other posts regarding this but I cannot get a answer that is definite. I currently have Verizon fios for all services. I would like to know how I can use the better of the routers with my current serivce and not loose any of the TV function (I believe I saw this can happen).
I currently have Verizon's Quantum Gateway router, if at all possible I would like to avoid using this or having to buy more equipment (bridges...etc).
so both these routers are tri band and to be honest there are very few ppl that can take advantage of tri band as most dont have any where near the amount of 5 gig devices to warrant buying a tri band over a dual band router
but the
netgear is as follows
1 x 5 gig low band 1300M
1 x 5 gig high band 1300M
1 x 2.4 gig 600M
linksys is
1 x 5 gig low band 2156M
1 x 5 gig high bamd 2156M
1 x 2.4 gig 1000M
the linksys will have a faster cpu and more ram as well
the linksys will prob have a bit better wifi coverage
so if you need this to run for all those other services you cant bridge it as you would need to run ether of those routers in AP mode or run in wan bypass mode as wifi only
ether of the above however bypass the router functionality , you just disable the wifi in the main router and use the wifi from the new router in ap mode
