Netgear WNDR3700 multicast support?
manta
Hi!
Do any of you guys know if Netgear WNDR3700 router supports multicast? I need multicast passthrough for IPTV. I've been searching all over the internet but i couldn't find any answer.
Maybe any other router that supports multicast, WAN->LAN speed 200mbit/s+ and gigabit lan ports?
Thanks!
Hi!
Thanks!
The user manual talks about things you can do to improve the streaming of MP3s and HD Video, but it doesn't get into multicast IP protocol support.
Yes
It does support muticast but there is a bug in the present firmware that prohibits this stream from the USB port on the router. If not using the USB to stream it works great. They are working on a fix.
Charlie C
