Netgear WNDR4000 N750 firmware upgrade
keef
Hello. I updated my router to the current firmware, then rebooted and all was well in the world and I logged out.
Now if I enter 192.168.1.1 it goes into an automatic check for the Internet then errors (404). When the lan cable from the modem is connected the results are the same. I have touched nothing. It goes to look for some page but cannot find it. The DNS is configured.
Must I have the modem attached to set the router up? Seems a bit odd.
Does anyone have an idea what went wrong and how I get back in? I tried holding the reset button in for 5 seconds but it always comes back up the same.
thanks, Bj
Well, routerlogin.net or .com will not work. Turns out going to speedtest.net allows me to configure the router. Weird.
Bj
