network monitor--KB/s?
Grievous Angel
Sorry if this is an insanely stupid question . .
. . and in general I find the available documentation on the admin panels to be thin and sparse, so any thing you can point me to on more comprehensive documentation would be appreciated . .
. . but the KB/s in the network monitor--is this Kilobytes Per Second or Kilobits per second?
I assume KiloByes per second but want to be sure.
Ok, that's what I thought. Thanks.
Which makes watching this traffic monitor pretty interesting.
We're streaming on Amazon Prime (Roku) and the behavior is interesting. I always assumed these streaming devices would sort of have a constant data usage. So, if you have, say, a 30Mbps connection (which I do) it would take up 3-5 Mbps constantly.
At least with Roku/Amazon, that isn't the way it works. It spikes about once every 30 seconds, taking up the entire bandwidth averaging 2500KB/s, which is around 20Mbps, if you believe this:
http://home1.gte.net/res0psau/bandwidth-unit-converter.html
So, for a few seconds every 30 seconds, it buffers like hell, then goes quiet for around 30 seconds. I assume for a slower connection it would just go a little longer.
I don't know if this is a Amazon/Roku thing but I find it to be a curiosity.
Roku-Netflix
You see the same data flow when watching Netflix on a Roku 2.
That is why IMHO when streaming video using a Roku that having a consistent PING and latency is at least as important as download speeds (above a bare minimum download speed ). Rokus don't have a lot storage to build buffers so when they need data they need it now.
Hmmm . .yesterday when I described that behavior (Amazon/Roku) we were watching Falling skies.
Today we are watching The Lorax on Netflix/Roku (MY KID IS PICKING THESE HONESTLY).
I'm not seeing the same pattern. It's spiky but pretty constant, and eyeballing it looks like around 500KB/s.
A far cry from a 2500KB/s "blast" and then "quiet/rest" pattern from Amazon.
And i just ran a speed test--50+mbps on my connection (for all the crap Charter gets, they rarely cap me at 30mpbs which is what I pay for).
I realize a lot of factors may go into this--different day, a butterfly flapping its wings--but it looks to me like different services have different strategies.
I'm using a Roku 3 if I didn't mention it.
None of this matters--it all works. I just find it interesting. Netflix behaves more along the lines of what I would expect from "streaming."
Streaming
When I stream my SlingBox across my LAN it averages 380 KB/s but with a peak of 780 KB/s.
Point being streaming isn't a smooth flow of data, but as long as your connection can keep up with the data requests your picture quality should be fine.
Both the Roku 2 and Roku 3 both use adaptive streaming to give you the best connection possible without rebuffering.
In my opinion Amazon's picture quality is better Netflix.
"In my opinion Amazon's picture quality is better Netflix."
Hmm. My impression was the opposite. I had been off of netflix for a couple of years but added it back with the Roku.
I may have to do a reference check.
Neither can touch Vudu, though. I understand it's a different service, but there's no way I'm going to "rent" a movie off of Amazon if it is available on Vudu.
Even more interesting, I was always frustrated with my PS3 and Xbox when using Amazon. Too often it would drop out of HD. It works much, much better on the Roku. Which I wouldn't expect given the resources of the consoles.
I don't think I've ever seen the Roku drop out of the HD stream on any service and I've had it a few weeks. I realize there are a lot of factors--load on the streaming service, internet factors, your own ISP, etc. But over time the Roku just works better. I guess their implementation is just a bit more efficient.
