mthacker
Hey SNB Community, First time poster here. Hope I'm in the right place.
I'm in the process of giving my girlfriend's home network an upgrade and could really use some advice. She lives in the basement of a 2 story rental house. Currently, the only internet connection for the entire house is a wireless router (Netgear WGR614v10) that is connected to the modem, located upstairs. I'm trying to improve the network in her basement unit by running a connection down to a new router, a TP-Link Archer C50, and then, from there, a wired connection into a switch in her room, where I hope to further improve the wifi signal using a Belkin N600 range extender. I've included a diagram, which I hope is helpful.
Right now I'm stuck. I've been using this wikihow article as a guide, but haven't been able to figure out how to configure "router mode" on the TP-Link router. On top of that, I'm not really sure which mode would be best. Setting it up LAN-LAN seems like the simple choice, but if I could set it up LAN-WAN we could block the upstairs neighbors from accessing the downstairs network and avoid potential interference.
I'm totally stuck and starting to feel like I'm bashing my head against a wall. I have some specific questions, but they all basically boil down to: how the hell do i do this!?
1. Am I using the right hardware? Is all this stuff compatible?
2. Which of these routers should be my primary, which one should be my secondary?
3. Should I use a LAN-LAN or LAN-WAN setup? Are there any good guides on how to do this?
4. I've had difficulty finding good information on how to get the routers to talk to each other. Can someone point me in the right direction to some resources that will show me how to get that done?
5. Is there anything else that I'm failing to consider that might give me trouble moving forward?
Big thanks in advance to anyone that helps!
