any idea why ?@all: Expect a new RT-N66U update from Asus in the (very) near future.
Effectively, the Xbox 360's maximum speed is severely crippled without the OfX option enabled. Assuming your internet connection is fast enough for it to be noticeable.
Simplest way to see the difference is with Netflix (outside of trying to find a good high-quality, high bitrate HD image to stream to the Xbox). Without OfX enabled, you can damn near guarantee that you'll never reach a speed that will allow Netflix to feed you an HD image. With it enabled, you should be getting close to, if not full, speeds to your Xbox 360 on your network, which allows you to achieve the "HD" signal strength in Netflix.
The issue many of us have had ultimately comes down to this:
We could use the newer driver and have the ability for the Xbox 360 to function properly BUT not have a stable 5GHz connection
-or-
We could use the older driver, have a stable 5GHz connection, but have the Xbox 360's speeds severely crippled.
I'm about to try out the newest FW in HOPES that my router will finally function properly on all fronts. I'll post back in a few days after testing it out.
I get an HD signal from Netflix with or without it. Even my old WRT54GL gives me and HD signal. Guess I have no issues with it. Thanks for your reply.
any idea why ?
Hrm... do you connect using the Xbox 360's own WiFi or did you buy the WiFi adapter?
Also, Linksys routers always tend to work properly for everything lol. For a while I circumvented the issue by using my ancient WRT54GS as my X360's own personal access point. The setup was adding a bit too much latency for me though so I ultimately stopped using it for that purpose. But essentially all is well and good for most folks until they're trying to just use the N66U's directly for the X360.
It's the older Xbox with no built in Wi-Fi. So I purchased the Microsoft Adapter and the 5 Ghz band works well. I use my WRT54GL for my G devices in which I stream 1080p video to my PS3 upstairs. I have a 35 Mbps connection so streaming HD is no problem.
Ahhh. Yeah that's why you're not seeing any issues. The adapter works fine. It's the internal wireless NIC that has the problem.
I also own 2 Gears of War 3 Xbox Consoles and it only finds the 2.4 Ghz band. Is it supposed to also find the 5 Ghz band? Which 360 do you have?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
