D
Dreamer001
Guest
Hello,
I know this is brought up often, but I am in the US and with the recent threats happening here I want to see what I can secure before I can't get new hardware to upgrade my RT-AX88U.
I wasn't as concerned about this before, but due to some construction my Fiber line was cut and AT&T just ran a new fiber line. After they did and performed the test, I was receiving 1400MB down and 1200MB Up on my 1GB connection from their tests. I also saw this using the AT&T Smart Home App. However due to limitations of the router with a 1GB WAN port (where the BGW320-500 modem I have has a 5GB Port), I only get around 940MB up and down. So only getting around 68% of my total download bandwidth.
I hadn't realized I was loosing that much bandwidth, as I figured 940MB of 1GB was pretty good, would like to tap into that extra ~400MB.
The only other issue I have with the AX-88U is I have my 5Ghz and 2.4GHz split and the 2.4 seems to loose internet connection sporadically, where I have to restart or wait a long time. Assuming this is interference or high traffic. Hoping not to have to deal with this with new router if possible.
Thanks in advance.
Thanks in advance.
