obmot
hi folks, newbie here I hope posting this in the correct forum/section...
I'm in NYC on time warner cable internet (no TV) and have signed onto FiOS. My current setup is time warner cable -> modem (surfboard 6141, I own) -> wireless router (netgear, I own and DD WRT provisioned).
I'm by no means an IT expert or guru like most here, but I've been flashing open source firmware/setting up routers for some years with no problem.
Anyway, I'm hoping to find out what are some 'gear setups' so as to - if possible...
1) dispense with annoying monthly rental fees for crapware; and
2) be able to (cross fingers) continue with dd-wrt as firmware for the wireless/LAN part ("router") because I know ddwrt like back of my hand.
I'm tentatively set up to get the "Quantum Gateway" from VZ blah blah blah but if possible I'd like to know *before* install date 8 days from now if there is a modem/router scenario that folks recommend at least vis a vis me reading up on. I don't want the install guy here for 4 hours to set stuff up that is crapware and which I can do 10x faster anyway. By analogy, if I moved to Dallas and I ordered time warner I'd say "turn it on from the pole, okay you can go now I got the rest from here"
I know that sounds rude - but you know what I mean....I'm not my mom/dad walking into bestbuy and clueless what "all the blinky lights mean."
Anyway thanks in advance for any FiOS setup guidance or pointers just in terms of what gear does work/others find better than renting etc.
That's all for now...apologies if this 1st forum msg is misplaced or not well received, I searched the forum a while and didnt see an on topic message.
