nginx not working after firmware upgrade from 380.XX
skywayskase
I upgraded the firmware on my RT-AC68U today from 380.65.4 to 384.5. Everything went pretty smoothly, and almost everything works except for NGINX. When I try to start it, I get the following error:
nginx: [emerg] getpwnam("nobody") failed (2: No such file or directory) in /opt/etc/nginx/nginx.conf:2
The second line in the config is just "user nobody" (without the quotes). I've ensured that an entry for "nobody" exists in the passwd file. I also reset to factory defaults (even though I really didn't want to) but I'm still having the same issue. I also tried changing the user to the root user in my nginx.conf file, but that only changed the user called out in the error.
I tried posting the path of said passwd file, to confirm it's correct, but anytime I type out the file path I get a message that I'm blocked from posting here and have to refresh the page. It's "slash etc slash passwd"
I had the same issue. I had to do multiple things.
First I had to do a full fresh re-install of entware (i tried a reinstall of nginx only first).
Then I had to reinstall nginx, and all my other dependencies for other stuff as well.
Finally I copied over my configurations from my backed up entware folder.
Now... it still didnt work. This time I hit a "binding error". I found the resolution for that here:
https://github.com/RMerl/asuswrt-merlin.ng/issues/79
As to why this wasn't an issue for me previously, I do not know other than perhaps an older, inherited nvram setting was overrode with the upgrade.
Yep, reinstalling entware and then nginx did the trick. Thanks for the tip. I wish it didn't have to come to that, but I'm glad it's working now.
Entware migrated to a new repository a few months ago, if you didn't follow the upgrade instructions provided in the Changelog then issues can happen.
Just to level set, I followed those instructions exactly for the repo change and upgrade etc. I still ran into this.
It's an install that's been running a couple years so something like this isn't all that surprising I guess. YMMV of course, but definitely follow the instructions. Hopefully me and OP were just flukes.
