Solved No GUI stats
I applied your fix but didn't reboot and got all the graphs except the following. Little concerned that shared-jy library gets corrupt upon reboot.
I use diversion so I don't use the unbound ad blocker. They can conflict.
Ok thanks. I added scMerlin. Not sure what it does but I'll give this a try until a better installer comes out. Thanks for all your help troubleshooting.
The beauty of scMerlin it does that does absolutely nothing unless you tell it too, cron job wise.
Only reason you want to install it now is so it creates the links required to mount your dependencies. It will also mount a page in your WebUI to reset services and whatnot which you don't have to use. (I basically never do)
If anything I only have it installed for the drop down menus as you mouse over the tabs lol
This one is the only one still empty even though I have firewall enabled...
If you want to test it, run this nslookup from a lan client. You should see a blip on the next stats update.
nslookup flyingmutts.com.
*** router.home.arpa can't find flyingmutts.com: Non-existent domain
I think it hit the "domain names doesn't exist". Firewall is still empty.
Odds are good then that the Adblock list used by Unbound already blocks the same hosts included in the urlhaus.abuse.ch malware rpz, making the DNS Firewall redundant.
FYI,
@juched [AKA @juched78] has approved & merged my pending PRs into his 'master' branch repository, so a new production release has become available now.
Release Notes for Unbound Stats WebUI v1.4.2 production version
[2025-June-12]
1) Fixed errors when loading the webUI page on the 3006.102.x F/W version.
2) Fixed issue with "missing scrollbar" on browser windows when the webUI page was loaded on the latest 3004.386.14 F/W version.
3) Improved code to make sure the symbolic link to the shared directory for JackYaz chart/graph files gets created during installation and startup (which includes reboots).
[In collaboration with @ExtremeFiretop]​
4) Improved ordering of function calls to create directories and links as the first steps during installation and startup.
5) Added "export PATH" statement to give the built-in binaries higher priority than the equivalent Entware binaries.
6) Converted texts to lower case to avoid warnings when a zone is duplicated because there are lowercase and uppercase versions, found in some adblock lists.
[PR #10 submitted by @RavenSystem]​
7) Miscellaneous code improvements & fine-tuning.
FYI,
[2025-June-12]
Forgive my ignorance, but I'm not seeing or remembering how to update the Unbound Stats WebUI when I already have it installed. Do I simply update Unbound itself? Uninstall the Stats WebUI piece and reinstall? Some other way I'm not seeing?
No ignorance, It's a good question. Someone can correct me if I'm wrong, but I see no other "official" method other than uninstalling and reinstalling the WebUI to get the latest version of the files:
FYI,
[2025-June-12]
Forked the Unbound WebUI into OSR for continued maintenance.
Will will advise once ready.
