Node LED setting not sticking
Ninko
Not sure if this is a bug or not, but whenever you make any network changes the LED setting for nodes appears to be ignored and they come on even though the setting is still off.
LED control is not propagated to nodes.
I'm using the GUI setting for the node, is this a bug then?
No, it's a technical limitation. LED control through the webui is my code, and I have no control over which settings AiMesh nodes synchronize.
Instead of through WebGUI, you can access AMTM of your node(s) and set LED control there. It works and it sticks.
After Read this post, I just tried the following:
AiMesh -> Topology -> Management -> Turning AiMesh Node LED ON/OFF works for my setup :)
Edit: Sorry, I think it does not survive reboot
Didn't realize Asus added a node LED control to AiMesh. In that case it's their implementation, not mine.
In my experience, AiMesh LED control has not always worked as expected. I prefer to do this via SSH each time.
If you are able to SSH in your node, then you can issue these commands and can change the number (0 or 1) depending on what you like to do. This will survive reboot.
nvram set led_disable=0
service restart_leds
nvram commit
(where 0 = LEDs 'on' and 1 = LEDs 'off')
Marin
