Noob Question re-port forwarding...
JemTheWire
I currently have a VPN server configured on my Asus AC- RT88U router so that I can access my local home network when I am traveling. Works great. I have also configured a VPN client via the AirVPN Manchester Dabih server. That too works well.
However, if I have both the VPN server (my own) AND the VPN client (AirVPN) enabled at the same time, I loose the connection to my home network when travelling. In a nutshell, the AirVPN client works, but the server does not.
In my noobness, I have set up port forwarding on the AirVPN client so that port 6xxxx is forwarded to my router. I have then set my VPN server's port on the same. I.E. 6xxxx. But when I try to connect to my router remotely via my VPN server, it doesn't connect.
Can someone help me, guide me hopefully, in simple 1>2>3 steps to complete my mission, which I am assuming is possible to achieve.
Note: I posted this question in the AirVPN forums and was directed here
Thanks in advance.
Make sure you aren't using the same port for both server and client.
I'm not now, it did try initially as per my original post #1, but have since changed to different ports. Still no dice.
But thanks for the reply.
There have been a couple of similar posts in the forum in the recent past regarding problems getting OpenVPN server and client running at the same time. You could look at Xentrk's suggestions here:
https://www.snbforums.com/threads/simultaneous-vpn-server-and-vpn-client.39508/#post-329065
And this might be worth a read too:
https://www.snbforums.com/threads/asus-rt-ac68u-openvpn-server-and-client.39061/#post-323813
(If you haven't already searched the forum, you may well come across more relevant posts.)
