noob setting up a vpn help
Veuxtres
because of BT and popcorn time, i read online ppls suggested to use vpn to secure myself, and i found the a website called strongvpn.
can someone explain some basics things to me?
if i signed that up for a $50 yr, and downloaded a client to my mac, turn on , login. and it works . correct ?
if that is it, what is the vpn setting in the router for ?
If You use vpn client on your pc only pc go over vpn if You setup on router all Devices go over vpn
Download speed is slower on router
ok i got it, if I'm using my router for bt downloading, should i purchase pptp or open vpn ?
and do i need a custom firmware for my router ? because I'm still using the official 1
Buy Openvpn doesnt matter router or pc always openvpn
I dont use official firmware cant say anything about that i use ddwrt
But on your router you will get max 20-30mbps speed (ac68u)
