Not pulling ipv6 block/prefix
icsy7687
This happened a few days ago. My isp uses a double NAT which means no public ipv4 address.
I have been using ipv6 addresses without issue. However now my AC68U won't put a block. However I can manually assign a block, but my isp recommend to not do this as it could cause a conflict down the road. They recommended fixing the issue to pull in IP addresses through the native functionality.
However when set to native, the router doesn't pull anything. Any suggestions?
Bump.
Just in case someone sees and it catches their eyes.
Currently I have a vps from ovh (about $3.50 a month) and an openvpn tunnel and some iptable rules to let me use it as my "wan" in a sense.
So luckily I can still access my services! It's a little slow but works. Miss my ipv6 addresses.
